This list was copied from the wiki and has not yet been updated.
Set-up and Measurement Tools
- SPI 4 piece combination square
- This is in the red tool box with the other measurement equipment
- 0-6" Dial Calipers
- In the black tool box
- 0-6"/0-150mm Dial Calipers
- Red toolbox, in drawer with other measurement equipment
- Center Finder
- Located in the drawer (labeled edge finder) in the end mill cabinet (on the workbench shelf)
- Dial Indicators
- Located in the top of the red tool box
- Dial Test Indicators
- Located in the black toolbox
- Edge Finder
- Located in a drawer (labeled edge finder) in the end mill cabinet (on the workbench shelf)
- Machinist Jacks
- A pair of machinist jacks for supporting odd shaped parts during set-up. Located in the top of the red toolbox.
- 0-1" Micrometer
- Noga Indicator Mount
- Located attached to the top of the red toolbox.
- Set of telescoping hole measurement gauges
- Used to accurate measure the diameter of holes from 5/16" to 6". Located in the red tool box drawer with the other measurement equipment
- 6" 5R steel rule
- In red toolbox, in drawer with other measuring equipment
- 18" 5R steel rule
- On order
- 600mm steel rule
- Located on the workbench shelf
