ItemOn HandReorder PointReorder QtyBrandVendorLink / ContactLast PriceLast PurchaseNotes
Festool
1Hard Pad EQ150
FestoolAmazonhttps://a.co/d/6v14Kiq52.0003/22
2Hard Pad Rotex
FestoolAmazonhttps://a.co/d/08mah76r42.00
3
4
5Domino 8 x 50 Box011FestoolAmazonhttps://a.co/d/0cNvWczd32
6Domino 8 x 100 Box011FestoolAmazon
7
Domino 10 x 50 Box
011FestoolAmazonhttps://a.co/d/07DWD4h132
8
Domino 10 x 100 Box
011FestoolAmazon
9
10
Festool 575162 Granat P80 Grit 6-Inch Box 50-pack
02 Box2 BoxFestoolAmazonhttps://a.co/d/0gyQFQGp51.006/20/24
11
Festool 575164 Granat P120 Grit 6-Inch (150mm) Diameter Abrasive Sanding Discs, 100-Pack
11 Box1 BoxFestoolAmazonhttps://a.co/d/06bz6gSh77.00
12
Festool 575166 Granat P180 Grit 6-Inch (150mm) Diameter Abrasive Sanding Discs, 100-Pack
11 Box1 BoxFestoolAmazonhttps://a.co/d/08fcr42p
13
 Vacuum
14Rigid Vacuum Filters - 8 Pack
RigidHome Depothttps://www.homedepot.com/p/RIDGID-General-Debris-Pleated-Paper-Wet-Dry-Vac-Cartridge-Filter-for-Most-5-Gallon-and-Larger-RIDGID-Shop-Vacuums-8-Pack-VF4200B/300500165127.0001/09/24
15Shop Vac - Filter
Shop VacAmazonhttps://a.co/d/7ViENQl19.58 ea06/01/24
1614 Gal / 6HP Shop Vac
RigidHome Depothttps://www.homedepot.com/p/RIDGID-14-Gallon-6-0-Peak-HP-NXT-Wet-Dry-Shop-Vacuum-with-Fine-Dust-Filter-Locking-Hose-and-Accessories-HD1400/304795071119.0001/09/24
 Saw Stop
17Saw Stop Regular Brake
Saw Stop
110.00
18Saw Stop Dado Brake
Saw Stop
19Standard Insert
Saw StopSaw Stophttps://www.sawstopstore.com/product/standard-table-saw-insert-with-lock-down-lever-10-blades/
20Dado Insert
Saw StopSaw Stophttps://www.sawstopstore.com/product/dado-zero-clearance-lock-down-insert/
21M5 Handle Key
Saw StopSaw Stophttps://www.sawstopstore.com/product/m5x5x22-key/
Powermatic Drum Sander
2280 Grit
PowermaticAmazonhttps://a.co/d/3kaVEhO
44.00
03/27
23120 Grit
PowermaticAmazonhttps://a.co/d/i3wOHB948.7503/27
24Powermatic Planer
24 15mm x 15mm x 2.5mm insert
ByrdHolbrenhttps://www.holbren.com/Byrd_Tool_B460029.95 10pcs
25T25 Torx Screw
ByrdHolbrenhttps://www.holbren.com/Byrd_Tool_B49000.40 ea
Safety
26 Ear Muffs
Harbor Freight Harbor Freight https://www.harborfreight.com/foldable-ear-muffs-58353.html7.49
27Safety Glasses
Bison LifeAmazonhttps://www.amazon.com/dp/B08QJT3R9Z179.00
28Face Shields 3pk
CopkinAmazonhttps://a.co/d/2eQyl8b28.99
29
30 Ear Plugs
 Amazon https://www.amazon.com/gp/product/B008MVYL7C/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Router Table
311/2" Round Over Set
YakamozAmazonhttps://a.co/d/b8yYg0o21.9903/17
321/2" Chamfer Set
WsooxAmazonhttps://a.co/d/9yfkZXY33.9903/17
331/2" Cove Set
YakamozAmazonhttps://a.co/d/2WrEHLg24.9903/17
341/2" Straight Set
YonicoAmazonhttps://a.co/d/b5pSrKb227.9503/17
351/2" Core Box Set
RoocbitAmazonhttps://a.co/d/3PD2UOJ29.6903/17
361/2" x 1/4" upcut spiral bit
Saw Blades
37610601 Carbide Tipped Heavy Duty General Purpose 10" Dia x 60T Tcg, 10 De
Amana Tool Amazon https://a.co/d/2IYQ5Dy
38610301 Carbide Tipped Glue Line Ripping 10" Dia x 30T Tcg, 22 Deg, 5/8 BO
Amana Tool Amazon  https://a.co/d/7EK5u3M
39Amana Tool - 610601 Carbide Tipped Heavy Duty General Purpose 10" Dia x 60T Tcg, 10 De
Amana Tool Amazonhttps://a.co/d/7WvhVUD
40
Supplies
41Glue-up Paper
House BrandWebstaurantStorehttps://www.webstaurantstore.com/24-x-1000-40-lb-white-freezer-paper-roll/43324FP.html51.49
42Combo Lock - Short 2 pk
AmazonAmazonhttps://a.co/d/fdpn1K77.72
43TiteBond III
AmazonAmazonhttps://a.co/d/66oXeR69.89
44
45
46
Fasteners
4718 ga 5/8"
MeiteAmazonhttps://a.co/d/85UbpOd13.5005/04
4818 ga 3/4"
MeiteAmazonhttps://a.co/d/dhHtk6G14.90
4918 ga 1"
MeiteAmazonhttps://a.co/d/324a9Gd16.9904/24
5018 ga 1-1/4"
MeiteAmazonhttps://a.co/d/9RNNVCq16.5004/24
5118 ga 1-1/2"
MeiteAmazonhttps://a.co/d/2YPMyST17.0004/24
5218 ga 2"
MeiteAmazonhttps://a.co/d/91Sfy3118.9004/24
53
54Pocket Hole Fine Thread 1-1/4" 600pc
LionMaxAmazonhttps://a.co/d/5x90u5327.9904/24
55Pocket Hole Course Thread 1-1/4" 600pc
LionMaxAmazonhttps://a.co/d/5dR5IcE25.9904/24
