Materials
With the following exceptions, members are expected to provide their own materials and consumables (including angle grinder wheels):
  • MIG Wire. The fee for using the DMS-provided wire (0.035") in the MIG welders is $1 for every 3 minutes of continuous welding.
  • Welding Gas. The gas provided for the welders has no additional cost for members.
  • Powder Coating Powder. Members can use the powders in the cabinet at no additional cost.
The following vendor lists are not intended to be comprehensive. If you have a favorite vendor that isn't on the list (or have edits/corrections), feel free to add it.
Plasma Table Consumable Vendors
VendorLocationOnline
Store
Metroplex Welding Supply
Alvarado, Dallas, Ft. Worth,
Grand Prairie, Mesquite
Airgas
Coppell, Dallas, Ft. Worth, Garland,
Grand Prairie, Lewisville
x
Powder Coating Vendors
VendorLocationOnline Store
Prismatic Powdersonline onlyx
Powder by the Poundonline onlyx
Metal Vendors
Store
PhoneProcessing/
Fabrication
Used/Scrap
Notes
Specialty MetalsArlington
800-365-1116x
Premium steel only. Knife, tool, high speed, powder metallurgy, alloy and stainless steels. Services include cut-to-length, sawing, surface and centerless grinding, gun drilling, boring, and trepanning.
SA Recycling (Lake June Scrap Metals)Balch Springs
972-288-0174
x
Busby MetalsCoppell
800-552-8729
Specialty metals only & high performance copper-based alloys
Ace Iron Metal
Dallas
214-631-2256
x
Arbor MetalsDallas
800-279-4515x
Coils & slitting
Chicago StainlessDallas
309-351-7462
Stainless coil, sheet, strip, plate
Dimco SteelDallas
214-428-8336
x
EMJ Metals (Jorgensen Steel)Dallas
214-741-1761x
King MetalsDallasx214-388-9834x
Architectural
Mandel MetalsDallas
877-752-5052
Aluminum only (coil, sheet, plate, tread)
McMurray MetalsDallas
214-742-5654x
Specialty metals only (hard to find brass, copper and bronze materials when others can not. Lots of drops).
Metals 4UDallasx214-231-1434
Primarily Aluminum, Steel, Stainless Steel, Brass, Copper
Quality MetalsDallas
971-331-6800
Primarily roofing
Southern Metals CoDallas
972-233-0757
Large wholesale of welder square and rectangular tubing. 1/2 to 16" square from 16 ga. to .625 & rectangle.
Texas Pipe & SupplyDallas
972-423-5296
Carbon & stainless pipe and fittings
Thompson-Mathis MetalDallas
214-826-1630x
Primarily sheet
Fulton Metal & HardwareDenton
940-898-1423
x
Alecom MetalEuless
972-438-1032x
Primarily Fabrication
Coremark MetalsFt. Worthx682-286-9922xxPricematching. Sheet in aluminum, stainless, stainless mirrored, copper, mild steel sheet & plate. Remnants section in showroom.
J&M Steel CoFt. Worth
817-289-4160
Steel round and square tubing, plate, sheet, rebar
JMS Russel Metals (Norton Metals)Ft. Worth
817-232-0404x
Full line of steel and aluminum
TW MetalsFt. Worthx888-558-7818x
Worldwide distributor of standard & custom metal pipes, tubes & tubing, rods, bars, extrusion & coi & sheet products. Fittings, hinge pin stock & roll formed shapes. Tubing types include 4130, DOM carbon, drawn or extruded aluminum, commercial & ornamental stainless nickel tubing. Coil & sheet products in aluminum, stainless, nickel & titanium.
WesTex Iron & MetalFt. Worth
817-626-7033
x
Sample Product Sheet. Scrap metal yard with lots of plate, square and angles, sometimes you can find fire hydrants for your garden. Mostly steel, some aluminum.
DFW Industrial MetalsGarland
972-276-2400
xFerrous and non-ferrous metals bought and sold. You can walk the yard and purchase by the pound.
Garland Steel Inc.Garland
972-494-6000
xHot rolled angles, flats, rounds, channels, pipe, tubing, plate, and sheet. Cold rolled flat bar, round, square, and hex.
Brown CampbellGarlandx800-472-8464x
Grating, perf, expanded.
Castle MetalsGrand Prairie
972-339-5000x
OnlineMetals.com (ThyssenKrupp) Grand Prairiex800-704-2157
Pricematching
O'Neal MetalsGrand Prairie
972-402-7900x
Laser, oxy-fuel, plasma cutting. Shearing, sawing, forming.
AmeritubeHillsboro
254-580-9888
Pipe and tubing
Rudy & Associates (MTW Metals)Kennendale
817-429-6916
Exotic grades of carbon, stainless, aluminum, alloy, and titanium. Services include bar coding & RFID, OD & ID cleaning, tube re-draw, centerless grinding & ID honing, heat treating, material testing.
Samuel & Son CoIrving
800-441-0797x
Almetco RecyclingLewisville
972-221-7442
xGood source of copper, bronze, brass
CDC Surplus ProductsRichardson
972-918-9886
xMechanical surplus: Cut-offs, hard plastics, aluminum, steel, various metals in smaller sizes. Drill bits, mill tooling, hand tools, high strength nuts and bolts. No credit cards accepted.
Trident MetalsRichardson
972-231-5176x
Carbon and specialty high-performance and corrosion resistant metals including aluminum, stainless, nickel, copper, and other exotics. Lead & ingot, magnesium, molybdenum, tungsten, zinc, silver, tin, tantalum, indium. processing includes boring, honing, turning, cutting, slitting, sheeting, shearing, and saw operations.
Holloway Co IncSaginaw
800-869-8663x
Structural steel rolling, plate rolling, ASME code vessels, shop fabricated tanks and custom plate cutting
Stephens Pipe & FencingWills Point
214-348-2400
Fencing-related metals
Multiple Locations
Metal Supermarkets
Dallas, Ft. Worth
x
Ryerson IncArlington, Carrolltonx
x
Grainger
Arlington, Carrollton, Dallas, Ft. Worth, Garland, Plano
x
Online Only
Midwest Steel Supply
x
Low cost cast aluminum plate
Metal by the Foot
x
Also carries patina copper plus taps, dies, and other misc tools
Online Metals
x
Large nationwide distributor
Speedy Metals
x
No minimum source of cast iron
