« Previous Version 6 Next »
DMS has two similar Sherline microlathes - a model 4000 lathe with 8" bed and a model 4400 with 17" bed and Digital ReadOut (DRO). The model 4000 lathe can be used in either manual or CNC mode, driven by electronically controlled stepper motors. Accessories are interchangeable.
SHERLINE 4000 CNC Lathe     CNC Controller for SHERLINE 4000 SHERLINE 4400 Lathe with DRO
Operation
  • (list operating restrictions here - no wood, etc.)
  • Return the lathe to the condition in which you found it.
  • If you reverse the chuck jaws, return them to the "normal" position before leaving. Instructions can be found on the instructions for the chuck (below).
Specifications
Model 4000 Specifications
Model 4400DRO Specifications
Standard dimensions of Sherline tools
SpecModel 4000Model 4400DRO
Swing Over Bed3.50″ (90 mm)3.50″ (90 mm)
Swing Over Carriage1.75″ (45 mm)1.75″ (45 mm)
Distance Between Centers8.00″ (200 mm)17.00″ (430 mm)
Hole Through Spindle.405″ (10 mm).405″ (10 mm)
Spindle Nose Thread3/4″-16 T.P.I.3/4″-16 T.P.I.
Spindle Nose Taper#1 Morse#1 Morse
Travel of Crosslide4.25″ (110 mm)4.25″ (110 mm)
Tailstock Spindle Taper#0 Morse#0 Morse
Protractor Graduations0° to 45° by 5°0° to 45° by 5°
Handwheel Graduations.001″ (.01 mm).001″ (.01 mm)
Length Overall23.5″ (597 mm)32.5″ (826 mm)
Width Overall10.5″ (267 mm)8.00″ (267 mm)
Height Overall8.5″ (216 mm)8.00″ (216 mm)
Spindle Speed Range70-2800 RPM70-2800 RPM
Documentation
Sherline MicroTools
Sherline microtools manual including 4000/4400 lathes
Sherline Accessories Guide
Sherline Accessories Help Sheets and Instructions
Sherline lathe parts exploded view diagram
Tutorials and Learning
Class notes: The notes used for the Sherline Lathe Intro class are available on the committee drive:
COMMITTEES / MACHINESHOP / SHERLINE / TRAINING
Video tutorials: An excellent set of Sherline-specific lathe tutorials from MiniMachining
Lathe tooling: The learning center at The Little Machine Shop has good descriptions of all of the various types of lathe workholding and tooling and what they are used for. While it is intended as a cross-reference to the products they sell, it also explains what these things are used for.
Accessories
PictureAccessorySpecificationsLinks
Work Holding
Sherline 1030.jpg4-jaw independent chuckModel 1030 3.1" chuck
Jaw capacity:
Normal position: 3/32″ (2mm) – 1-3/16″ (30mm)
Reverse position: 3/32″ (2mm) – 2-1/4″ (56mm)
Instructions
Sherline 1040.jpg3-jaw centering chuckModel 1040 3.1" chuck
Jaw capacity:
Reverse position: 3/32″ (2mm) – 2-3/4″ (70mm)
Instructions Media:1040inst.pdf
Sherline 1076.jpg4-jaw centering chuckModel 1076 3.1" chuck
Jaw capacity:
Normal position: 3/32″ (2mm) – 1-1/2″ (38mm)
Instructions
Sherline 4007 4009.pngFaceplate and Drive dogModel 4007 Faceplate/4009 Drive dogInstructions
Sherline 1074.jpgSteady restModel 1074
Parts up to 1.75" diameter
Description
Instructions
Sherline 1090.jpgFollower restModel 1090Description
Instructions
Cutter Holders
Sherline 3057 rocker.jpgRocker tool postModel 3057 for 1/4" toolDescription
Sherline 2250 quick.jpgQuick change tool postModel 2250, with 3 positionsDescription
Instructions
Sherline 7600.jpg3/8" tool holderModel 7600 for 3/8" round or square shank tools
Intended for use with insert holders (boring)
Instructions
Boring Tools
Sherline 2259-2260.jpgRH Carbide insert holder for boringModel 2259 - 80 degree insert holder
Starting hole 0.5", Max depth 2"
Model 2260 - 55 degree insert holder
Starting hole 0.75", Max depth 2"
Instructions
Sherline 3061.jpgBoring barsModel 3061 - Starting hole 0.25", Max depth 0.6"
Model T3061 - Boring tool with special undercut
Model 3063 - Starting hole 5/16", Max depth 1"
Model 3064 - Starting hole 5/16", Max depth 1.5"
Instructions
Specialty Accessories
Sherline 1206.pngTailstock Threading Die HolderModel 1206
Die holder for 1" and 13/16" button die holders
Instructions
Sherline 2200.pngRadius cutting attachmentModel 2200
Internal radius, external radius, ball up to 1.5" diameter
Notes on using
- original maintained in Machineshop Committee files
Instructions
Sherline 3004.pngKnurling tool holder with knurlsModel 3004
Diamond-shaped knurls for diameters up to 1"
25TPI 30 degree RH and LH knurl tool
Knurled knob example.jpg Knurled example (not included in kit)
Notes on using
Instructions
