The Torrent 400 provides industrial-strength cleaning power for intricate parts that require a "hands-on" approach without the health risks of traditional solvents. Using a combination of heat, chemistry, and 500 PSI of water pressure, it can clean complex geometries, such as cylinder heads or transmission casings, in seconds.
How it Works
High-Pressure Cleaning: A foot-pedal-operated pump delivers a concentrated spray at 500 PSI, allowing you to blast grease out of blind holes and crevices.
Ergonomic Design: Users interact with the parts through heavy-duty integrated gloves while viewing the work through a clear, pressurized window with a built-in wiper.
Heated Aqueous Solution: The system uses an eco-friendly, water-based detergent heated to 115°F - 120°F to accelerate the breakdown of hydrocarbons.
Quick Specs for Users
Max Load Weight: 110 lbs (50 kg).
Working Area: Large enough for most automotive components and large 3D printed assemblies.
Visibility: Features a high-intensity light and an air-knife system to keep the viewing window clear of steam and splashes.
- Soft-Metal Safe: Should be is safe for aluminum, copper, and brass, but you need to confirm
Standard Operating Procedures (SOP)
Preparation: Check that the heater is active. The solution must be warm to be effective. To extend the life of the fluid, the majority of grease should be removed prior to placing the parts in the unit.
Loading: Place parts on the internal grate. Ensure the heavy lid is fully latched all the way around before starting.
Operation: Activate the power switch at the front of the unitl, insert hands into the gloves and use the foot pedal to activate the spray. Use the high-pressure nozzle to target heavy grime, agitate with a brush if needed.
Rinse & Dry: After cleaning, use the integrated air-blow gun to dry the part and prevent flash-rusting before removing it from the cabinet.
- Cleanup: After completion, make sure to clean up the internal space, any brushes used.
Safety & Compliance
Personal Protection: Because the unit is fully enclosed, it eliminates the risk of splashing chemicals on skin or inhaling harmful vapors. Make sure to wear clean gloves when using the unit to avoid contaminating the gloves.
Waste Management: All grease and oil are captured in the internal filtration system. Raise and issue on Talk to the #Team_Automotive if the water level is low or the pressure feels weak.
| Name | Torrent 400 |
| Training | Training Recommended |
| Manufacturer | NCH or Partsmaster |
| Description | Fully enclosed water based parts cleaner with 3 key elements: high pressure, heat and degreaser. |
