There is a material hardness limit. It must be a Vickers Harness (HV) of 200 or less on the printing surface.
Common Acceptable Material Types:
- Aluminum, Brass, Bronze, Copper, Mild Steel, Yellow Gold, Silver, Nickel (surface must have a luster finish or plated)
- Plastic or acrylic (transparent or semi- transparent for best results
Not Recommended Material Types:
- Material with a Matte surface
- Deep acrylic colors, opaque plastics
- Glass, stone, china, porcelain and wood
- Rubber or elastic type of plastic
Example Curved Surfaces:
- Pen
- Bracelet
- Rings
Q: What is the printable area of the MPX‐90?
- A: The MPX‐90 has a printable area of 3.15”x3.15” (80mm x 80mm) with a Z clearance of 1.57” (40mm).
Q: What is the largest item I can place into the MPX‐90?
- A1: With the cover open, the MPX‐90 can accommodate:
Length: 3.94” x ∞ (100mm x ∞)
Width: ∞ x 3.94” (∞ x 100mm) - A2: With the cover closed, the MPX‐90 can accommodate:
Length: 3.94” x 7.87” (100mm x 200mm)
Width: 7.87”x 3.94” (200mm x 100mm)
| Name | Roland Metaza MPX-90 |
| Manufacturer | Roland |
| Description | The MPX‐90 has a printable area of 3.15”x3.15” (80mm x 80mm) with a Z clearance of 1.57” (40mm). |
Manual: Impact Printer MPX-90_USE_EN_R5.pdf
Software: https://downloadcenter.rolanddg.com/MPX-90#software
