« Previous Version 3 Next »
This is just a cut a  paste from the Wiki.  It will need to be updated.
Reference
  • \\files\committees\machineshop
    • Manuals
    • Lubrication Chart
    • Parts List
    • Accessory Parts
  • Parts and Manuals for purchase [ Needs to be researched, the original link provided on the wiki now leads to a malware site: http://fdk3co.com/ ]
Specifications
Copied from user manual found in Committee Files.
Centers
Leadscrew
Height6.5 in
Diameter1.125 in
Dist between40 in
Thread4 T.P.I.
Swing
Threads
Over bed13.25 in
Metric pitches0.2 - 14 mm (39)
Over cross-slide8.25 in
Imperial T.P.I.2 - 72 TPI (45)
In gap19 in
Module pitches0.3 - 3.5 MOD (18)
Length in front of spindle nose4.5 in
Diametral pitches8-44 D.P. (21)
Spindle
Feeds
Bored to pass1.625 in
Metric (R10 Series)0.03mm - 1.0 mm
Nose type4 in. D.1 camlock
Imperial (R10 Series)0.001 in x 0.040 in
Morse taper in bush3 MT
Cross feeds = half longitudinal
(approx) values
Spindle Speeds
Height of Machine
No. off16
Floor to spindle center41.75 in
Selected in four ranges of
four speeds in each range
..30.......40.......54.......72
Overall Length
..98......130......175......235
40 in. machine78 in
.320......425......570......770
Weight
1030.....1380.....1860.....2500
40 in. machine890 kg (approx)
Bed
Cross-slide
Width of ways9.125 in
Width and length5.875 in x 19.125 in
Type of waysVee and flat
Travel8.25 in
Top slide
Tailstock
Width3.5 in
Quill Diameter (nominal)2 in
Travel3.75 in
...travel5.75 in
Tool section1 x 1 in
...Morse taper3 MT
Quick change toolingDickson No. 2
Set over(0.250 in)
Motor (main)
Coolant pump unit
1800 r.p.m. (60 Hz)3.7Kw (5HP) Cont.
Type AQ3 50/60 Hz1/20 h.p.
L184T Frame size
Tasks
Cleaning
  • (Done) Use Scotch-Brite pads to remove surface rust
  • (Done) Clean and re-oil ways
  • (Done) Clear oiling ports throughout machine
  • (Done) Coolant tank cleaned
Lubrication
  • Replace all oils per manual
Connect Electrical
Motor in unit is 230v 3 phase which may be a problem at the space. Check with Infrastructure.
  • Add pig-tail and plug
Coolant pump
  • Verify it works
    • If not, what's needed to get it working?
  • (Done) Attach spigot to cross-slide
  • (Done) Find out how to install collection tray
Collet Closer
  • (What is this?) Figure out how it attaches and works
Tool Holders
Figure out where they will go and attach them
BXA ToolPost
  • Install
Make new Speed Selector Handle
  • (Done) Repaired old unit with epoxy, mounted, seems to work fine
Misc Maint
  • (Done - yes) New Belt(s)?
Verify operation
  • Check that all features work as they should
6" Chuck Backing Plate
  • Turn and Mill to fit small 4-jaw
Acquisitions
  • Backing plate for 6" 4-jaw (Done)
  • Face Plate (Done)
  • Large 4-Jaw (Done)
  • 5C Collet chuck (Done - Collet closer)
  • Plate to attache BXA Quick-Change Tool Post
  • Aluminum for speed selector handle
  • Pigtail and plug
Name
Clausing-Colchester Lathe
Date Acquired
Training
Training Required
Manufacturer
Clausing
Description
Manual Lathe
Volunteers
