This is our baby CNC machine. In this section you will find information to help you get the most value from our X-Carve machine.
- Create your Easel account to access the free software.
- Go through the various tutorials listed below
- Take a couple of Make-and_take classes or the getting familiar with X-Carve class(coming soon).
- Take a short quiz on Moodle to verify you understand the basics.
- Create the simple test cut file you will receive after you pass the quiz.
- Set a day and time with one of the X-carve coach/tester folks.
- Demonstrate you can run your simple job and then you are set to go.
