« Previous Version 16 Next »
This is our baby CNC machine.  In this section you will find information to help you get the most value from our X-Carve machine.
Replacement Cost
Please be careful with our machine because it will cost us around $2500 to replace it with the current model.
https://www.inventables.com/products/x-carve-1
  1. Create your Easel account to access the free software.
  2. Go through the various tutorials listed below
  3. Take a couple of Make-and_take classes or the getting familiar with X-Carve class(coming soon).
  4. Take a short quiz on Moodle to verify you understand the basics.
  5. Create the simple test cut file you will receive after you pass the quiz.
  6. Set a day and time with one of the X-carve coach/tester folks.
  7. Demonstrate you can run your simple job and then you are set to go.
Get started now
Intermediate Techniques
Easel Intermediate Techniques
Bit Selection
Learn About Router Bits
