« Previous Version 29 Next »
This is our baby CNC machine.  In this section you will find information to help you get the most value from our X-Carve machine.
Basics of how this process works
Replacement Cost
Please be careful with our machine because it will cost us around $2500 to replace it with the current model.
https://www.inventables.com/products/x-carve-1
  1. Create your Easel account to access the free software.
  2. Go through the various tutorials listed below
  3. Take a couple of Make-and-Take classes or the Becoming familiar with X-Carve class(coming soon).
  4. Take a short quiz on Moodle to verify you understand the basics.
  5. Create the simple test cut file you will receive after you pass the quiz.
  6. Set a day and time with one of the X-carve coach/tester folks.
  7. Demonstrate you can run your simple job and then you are set to go.
Session Limits
Members are limited to 1 hour sessions during peak usage times(people are waiting).  If you have a complex job(2+ hours) then run it during off the off hours 10PM - 9AM.  Pleading ignorance of the job's run times isn't acceptable since it is shown at the bottom of the preview.  This rule will be enforced when people are waiting in the queue.  If you are careful, you should be able to remove your job from the machine and return later and continue running the tool paths.
Learn the X-Carve Machine
Preparing for your Knowledge Quiz
X-Carve Quiz Prep
X-Carve Machine Proficiency Demonstration
Make & Take Classes
Members from several committees are currently exploring awesome classes.  This is a great way to gain experience before investing the time to learn everything.
Get started now
Intermediate Techniques
Easel Intermediate Techniques
Bit Selection
Learn About Router Bits
Use Multiple Bits
Use Multiple Bits
X-Carve Projects
X-Carve Projects
