TBD - New overhead map with non-duplicated RTU numbers and the Goodman unit included. (RDRC likely to provide in April 2023 as part of Preventative Maintenance agreement)
We have a Preventative Maintenance (PM) agreement with RDRC Mechanical.
- April (Spring)
- July (Summer)
- October (Fall)
- January (Winter)
RDRC Accounting sends out an invoice at the beginning of the month in which they will perform the work. Receiving an invoice does not mean they have completed the work in that month.
The executed agreement is available on the Infrastructure Committee G-Drive.
Description of Services
DESCRIPTION OF SERVICES
OUARTERLY SERVICE INSPECTIONS O INCLUDE:
* Check and record operating voltage on all equipment
* Check and record phase balance on all equipment
* Check and record amperage draws on all equipment
* Check equipment electrical contactors
* Check equipment wiring for over heating
* Check system staging and operation
* Check oil and refrigerant levels
* Check bearings and motors
* Lubricate motors and drives
ANNUAL SERVICE INSPECTIONS TO INCLUDE:
* Calibrate all safeties and operational controls * Chemical Clean Air Cooled Condenser Coils (splitting condenser coils and cleaning are
additional charge)
* Clean Evaporator Coils and Condensate Drain. This will include checking the integrity of all
condensate pans and installing pan tabs.
| ID No | Mfgr | Model No. | Serial No. | Thermostat Location | Plan Coordinates |
| 102 RTU 1 | CARRIER | 48TMD008-A-501-- | 0308G0643 | Wall @ exterior door between 3D Fab and Electronics | |
| 102 RTU 2 | TRANE | YSC120A3ELA1F | 406100229L | Column in flex area between Science & Printing | |
| 102 RTU 3 | TRANE | YSC120A3ELA1F | 406100302L | Lobby | |
| 102 RTU 4 | CARRIER | 48TJD006---511GA | 3899G21027 | Common @ Infrastructure Office | |
| 102 RTU 5 | LENNOX | ZGB092S4BS1Y | 5618G06452 | North warehouse, column, facing Jewelry | E120 x S040 |
| 102 RTU 6 | LENNOX | ZGB092S4BS1Y | 5618G04125 | Column, near Machine Shop & Blacksmithing | |
| 102 RTU 7 | LENNOX | KCB180S4BN1G | 5618E04674 | North warehouse, column, facing away from Jewelry | |
| 102 NETWORK ROOM | DAIKIN | RX36NMVJU | G009004 | MS (Mini Split) | |
| 104 RTU 1 | BRYANT | 580FPV060074AB-- | 3707G40164 | Column, Pillar of Solitude | |
| 104 RTU 2 | CARRIER | 48HJD006---541-- | 2408G20399 | Hall @ Animatronics Lab | |
| 104 RTU 3 | LENNOX | ZGB060S4BM1Y | 5617H10903 | Interactive | |
| 104 RTU 4 | TRANE | YSC060E3ELA1N | 145112840L | Creative Arts, interior wall | |
| 104 RTU 5 | CARRIER | 48TJD006---511GA | 4799G20920 | Column near Laser | |
| 104 RTU 6 | BRYANT | 580FPV060074AB | 4007G20239 | Lecture | |
| 104 RTU 7 | LENNOX | ZGB060S4EM1Y | 5622M01300 | South warehouse, column, facing future Woodshop | |
| 104 RTU 8 | LENNOX | ZGB060S4BM1Y | 5617H10665 | South warehouse, column facing opposite future Woodshop | |
| 104 RTU 9 | LENNOX | ZGB120S4BS1Y | 5620D08932 | Woodshop near Multicam | |
| 104 RTU 10 | GOODMAN | WORN OFF | WORN OFF | Old 104 Networking room unit - was replaced by MS and is not used. | |
| 104 NETWORK ROOM | DAIKIN | RX36NMVJU | G009006 | MS (Mini Split) |
