This page is being reconstructed and might not contain correct information: If in doubt, please ask!
Computer (HDMI)
- Turn on the Projector using the Epson remote control
The projector will "click", then the light will turn on. The projector screen will drop down after about 15 seconds
- Turn on the receiver
- Rotate the Input dial on the left to HDMI3 (Computer)
- Plug in the white HDMI cable coming from the back of the receiver to your computer
- Adjust the volume by turning the right dial on the receiver
When you are done
- Disconnect the white HDMI cable from your computer
- Turn off the Receiver (upper left button on Receiver)
- Turn off the Projector
Turning off the projector will increase the life of the bulb. The projector will turn itself off and the screen will automatically retract after 5 minutes. Wait for it to turn off, or press the power button on the white Epson remote control
Computer (VGA)
- Turn on the Projector using the white Epson remote control
- Plug in the white HDMI cable coming from the back of the receiver to the VGA Adaptor
- Hook up the VGA Adaptor to your computer
- connect to the VGA port
- connect the USB port for power (may need to use USB extension)
- connect the audio (may need to use audio extension)
When you are done
- Disconnect the white HDMI cable from the VGA Adaptor
- Disconnect the VGA Adaptor and cables from your computer
- Put the VGA Adaptor and cables back in the box
Computer (DisplayPort)
- Attach DisplayPort device to Receiver
- Find the DisplayPort to HDMI Adaptor in the Adaptors box
- Plug the Adaptor into laptop
- Plug in the white HDMI cable coming from the back of the receiver to the DisplayPort Adaptor
When you are done
- Disconnect the white HDMI cable from the DisplayPort Adaptor
- Disconnect the DisplayPort Adaptor and cables from your computer
- Put the DisplayPort Adaptor back in the box
Composite (Front Panel Yellow/Red/White RCA)
- Rotate the Input dial on the left to V-AUX
When you are done
Chromecast
- Connect to the Chromecast named "Lecture Hall"
- Rotate the Input dial on the left to HDMI2 (Chromecast)
- Adjust the volume by turning the right dial on the receiver or use the volume controls on the Chromecast client
When you are done
Blu-ray or DVD
- Turn on the Blu-ray player
- Rotate the Input dial on the left to HDMI1 (Blu-ray)
- Adjust the volume by turning the Volume dial on the right
When you are done
- Eject Blu-ray or DVD disk (upper right button on player)
- Turn off the Blu-ray player (upper left button on player)
Android/MHL
- Attach Android/MHL device to Receiver
- Find the Android/MHL to HDMI Adaptor in the Adaptors box
- Plug the Adaptor into MHL device
- Plug in the white HDMI cable coming from the back of the receiver to the MHL Adaptor
When you are done
- Disconnect the white HDMI cable from the MHL Adaptor
- Disconnect the MHL Adaptor and cables from your computer
- Put the MHL Adaptor back in the box
Mini HDMI
- Attach Mini HDMI device to Receiver
- Find the black Mini HDMI to HDMI cable in the Adaptors box
- Plug the cable into Mini HDMI device
- Plug in the white HDMI cable coming from the back of the receiver to the Mini HDMI cable using the attached red HDMI/HDMI Adaptor
When you are done
- Disconnect the white HDMI cable from the Mini HDMI cable
- Disconnect the Mini HDMI cable from your device
- Put the Mini HDMI cable back in the box
Technical Information
Technical information about the equipment including some serial numbers and manuals can be found on the Classroom page.
