Version 1 Current »
This page is being reconstructed and might not contain correct information:  If in doubt, please ask!
Contacting
If the classrooms need some maintenance that you are motivated to take care of it, but just need funding or want assistance accomplishing this task? Just email [email protected].
Overview (Guide to Rooms)
There are six general use classrooms. Their capacities and default set-ups are detailed in Rooms Guide.
Lobby Classroom
Lecture Hall
Lecture Hall Presentation Guide How to use the equipment
File:Lecture Hall Presentation Guide.pdf Lecture Hall Presentation Guide PDF
Mu/th/er: Lecture Hall node
Monitor the Epson PowerLite HC-8350 Projector
The main goal here is to help preserve the projector lamp by:
  • monitoring the temperature of the air at the projector's
    • intake
    • exhaust port
RS-232 interface
  • male db9 connector"To use an AV controller with the projector, connect a 9-pin null modem serial cable to the RS-232C port."
Yamaha RX-A840 Receiver
Onkyo HT-460 Receiver
This device should be set to accept its input from HDMI 1 to get its signal from the Receiver.
Replacement Bulbs
Epson V13H010L61
3 Nov 2014 - Used bulb from Robert Davidson is now in operation.
links as of 1 July 2015
Theoretically can get the bulbs for maybe, just maybe $250:
  • from
    Atlas Electronics (John)2737 Irving BlvdDallas TX 75207(214) 631-2901
  • Was referred by
    Randal (sp)North Dallas Home Theater(214) 597-7714
Interactive Classroom
Vizio LCD TV (west)
  • Model: E601i-A3B
  • S/N: BFLFTRNWAN4421425
Vizio LCD TV (east)
  • Model: E601i-A3B
  • S/N: BFLFTRNWAN4323209
VGA to HDMI Adaptor
  • Model Name: USB+VGU+Audio to HDMI
  • Model No: SY-ADA31025
  • other marking: LAN08070546
North Conference Room
Vector
Westinghouse LCD TV
Note: This TV was moved from the Ladybird Classroom into the meeting room because this television did not interface well with the Onkyo Receiver.
acoustic panels
Class Sign In Sheet
Public Google Doc https://docs.google.com/document/d/1qwoKNuEzF-uL135_Shne2RlDSLjSSxI7oRXtlitNnWc/edit?usp=sharing
