A CNC laser cutter is a computer controlled tool for engraving and cutting. It uses a high-powered laser to burn through material, leaving a very crisp cut.
Thunder Nova Lasers
- "Big Thunder" Nova 63. 1600mm x 1000mm (63” x 39.4”x 9.8”); 130 Watts of Power
- "Donner" Nova 35 (next to Fusion). 900mm x 600mm (35.4” x 23.6”x 9.0”); 130 Watts of Power
- "Blitzen" Nova 35 (next to Big Thunder). 900mm x 600mm (35.4” x 23.6”x 9.0”); 130 Watts of Power
- Manufacturer's website
- Manufacturer's Manual Nova 63
- Manufacturer's Manual Nova 35
- Manufacturer's Suggested Material Settings
- Manufacturer's RDWorks Manual
- Manufacturer's YouTube Channel
- RDWorks Software Manual from RDWorks Lab (non-OEM)
Notes Regarding Head Crashes:
- Don't put anything in the way of the head so that it crashes. The thin metal slats have been specifically chosen to help avoid head crashes.
- The Thunder Laser Nova 35 & 63 have servos (steppers with optical encoders). If it senses a lot of skipped steps it just gives up and assumes something has gone terribly wrong. This can crash the head. Resetting the machine clears things and it should go back to normal operation.
- The "reset" button also helps when the machine loses track of its place. It forces a re-Home and then rights itself. This can happen with the rotary attachment too.
(Note: this link to be deleted when page retired) Wiki page for Thunder Laser - https://dallasmakerspace.org/wiki/Thunder_Laser
Epilog Zing Laser
- 12" x 16" x 4"; 30 watts.
- HEPA Filter: http://www.quatro-air.com/sph400-laser-fume-extractor.html
- Zing Cart
- At the time of writing (7/1/2020) zing cart is in progress
- Zing
- Computer
- HEPA Filter
- Air Pump
- UPS (for Zing, computer, and air pump
Epilog Fusion Pro 32
- 32" x 24"; 60 watts
- Roller-style rotary attachment
Square Receipt Printer
How to refill (with diagram) and where to find refills: https://talk.dallasmakerspace.org/t/reaolved-laser-receipt-printer-out-of-paper/36458/3
